Tried to renew the fuel filter on my Fiorino Van today, a job that I have managed successfully on other diesel engines in the past. I removed the old filter and then found that I had been supplied with the wrong replacement, so I put the old filter back on (it was still about half full of diesel) and attempted to bleed the system up again. I opened the bleed nut on the top of the filter housing and turned the engine over for a while. The engine spluttered and fired a few times to begin with but then failed to fire atall and no diesel bubbled out of the bleed nut. I removed the filter again and found that it was now completely empty (so the spluttering and firing must have been using up the fuel that had been left in the filter)
I then turned the engine over with the fuel filter completely removed to see if any fuel was being pumped up to the filter housing. No fuel spurted out atall. I can't find any way to pump fuel manually through the sytem.
Can anyone let me know how to bleed the system properly. I seem to be making some basic error.
By the way, the fuel tank is almost full to the brim and I even checked to make sure that the inertia fuel cut off switch in the passenger footwell hadn't by some weird coincidence tripped.
