Technical Fiat stilo strange problem with window on passenger side
escobar
I have a 2002 Fiat Stilo 3 doors and a week ago a strange problem on pessengers side apperd. Always when I opened or closed windows in the driver's or passenger's side, pressing the switch to open / close the windows automatically closed or open. On the driver's side window working well but on passenger side when i press the switch to close the window now the windows rolls up only if i hold the switch, it wont close automatically but when i press the switch to open window then it automatically open all the way down like it should. I hope I wrote enough to understand my problem. Has anyone ever had such a problem? What could be wrong? Please Help :bang:
Hi, Welcome to the FF.
It's likely that you have a problem with the Anti Pinch Sensor in the door. There's a thread about it here:
https://www.fiatforum.com/stilo/174770-anti-pinch-sensor-fault.html
Also, if you use the "search" button on the red bar at the top of this page and search for "Anti Pinch Sensor", there are lots more posts about the problem.
no i checked it's not anti pinch sensor. Where's the control unit for windows? Maybe the control unit is faulty
The door control units are inside the doors.
maybe if i disconnect control unit from the power source and connect back it could work again. I hope so. On one forum someone wrote there is a learning mode for windows or control unit. Is this true?
Ain't you supposed to open and/or close the windows completely and hold the switch for a few seconds to relearn?
gr J
i have tried that but with no luck. Can you write me a more detailed procedure for relearn.
