Hi all,
just bought a Seicento sporting 1998 two days ago; after 15km on the way home it overheated and smoked twice
so another garage had to change thermostat and flush cooling system for me as it was blocked. Car was fine on a test drive a week and a half ago, no noise no overheating. Overheating is now solved with the above but the car still makes a squealing noise particularly on higher revs in 1st, 2nd, 3rd gears, not so much/not at all in 4th/5th; e.g. coming out of a corner in 2nd will make the squeal louder. Garage who replaced thermostat are saying it is the bearings in the alternator and would cost about another 150 Euros to change the bearings. Through other forums i've seen it could also be minor things like the belt tension (which i could try and remedy myself) or more major issues including water pump. What do you think, and can I test more and give you any other symptoms? Thanks!
