Technical Fiat punto mk2 head gasket URGENT
nickpaokgr
hi i have a punto 188a4000 (1242 8v) my head gasket is gone and i found a gasket that is the same looking one but it's from an older engine (dunno which one). The replacement will be done by me mechanic friend of mine. He's never done gasket on 8v before so he doesn't know. Some co workers of him told him this gasket we found can be placed on the mk2 8v. So i m asking you, can this be done? Can the mk2 take gasket from other model ? If yes from what models?
thanks in advance
edit1: the gasket is from fiat doblo
edit2 the doblo gasket has stripes around it, while ours is smooth . But from the inside it's 100% the same. Both are 188A4000
edit 3
doblo gasket is like this :
While mine is :
i saw some posts that said the the gasket need some modification to fit, is this true? or will it fit 100% like it is.
thanks once again
Part numbers can be a minefield.
Getting the right one is not always a guarantee. Having different numbers does not necessarily mean that the parts are different.
I bought aftermarket from the local factor and had no issue.
