Technical Fiat Punto 2005 1.2 Diesel
TKarafou
Greece
Hello,team
recently my fiance got a Fiat punto 2005 diesel 1.2
we where driving to go to sea (summer in Greece :D ) we acounter some bumps on the road,when was the time to leave we have a strange problem....
the dashboard was not working,only when the engine is off and opening and closing the door it displays the time and total kilometers
i checked the fuse its ok,i removed the dashboard and checked the voltage ,i haved 12 and 14 the i start the car,i disassembled the dashboar6d to check the voltage(check photo)
Model
1.2 diesel
2005
Mileage
198000
  • IMG_2265.mp4
    4 MB
It is a bit hard to tell from the photo, but sometimes the traces of the PCB solder can minutely crack, yielding the issue you described. It is worth a check, and fairly easy to look at/remedy.
i found the problem,the STOP lights fuse gives the dashboard power when you turn on the ignition,when you have the ignition off it takes power from the dashboard fuse......
