Hi Guys
Reviving a very old thread started by me.
I had almost given up on my car, was on even the verge of selling it.
The engine belt issue was still pending.
AC had stopped working
Brakes had lost all the power
Electrical issue (Headlights, Front power windows, central locking would stop and start at its own will)
Suspension overhaul needed
Could not find someone who could confidently do it. For some reason, all good garages in Mumbai were shying away from doing any critical work on Fiats. A.S.S. had already left us high and dry since years
Then for some reason, I thought to give one final try. Then I came across one garage called R.S. Motors who had a team which earlier worked for Fiat Authorized service centre.
Got the brake issue and belt changes done from them and they have done a quiet a neat job. Only regret was I could not upgrade to Advernture brakes which have bigger discs. The garage said Advernture OE parts are hard to come by. I thought since i am changing basically the whole brake setup except for brake booster, it would have been a good idea to change to Adventure brakes.
Anyways, not a big issue as my car runs only in city and speed never exceeds 70 kph
The electrical issue cropped up again after getting all the work done but luckily i have got a temporary fix to it
I need to whack the fuse box located under the dashboard on drivers side a little and all works fine
A week ago i came to know about this website called
www.99rpm.com which sells parts for Palio, siena, punto and liena. Its an India based company and one of its kind because there are hardly any online sellers in india for car parts. They are selling FIAT parts which are as it is hard to find in the market. Owner is very helpful
I plan to do a suspension overhaul next ordering parts from 99rpm.com.
Following is the list of suspension parts. Please help me if i have to add anything
Tie Rod End
Lower arms (Control arms)
Anti Roll Bar Bush Kit
Front struts
Front Strut Rubber kit
Suspension Pads
Rear Struts
Rear Strut Rubber Kits
Not sure if i need to change the following
Coil Spring
Camber Bolts
Knuckles
Next would be tyre change and body repaint and headlight change with bulb upgrades
Hope after this it will be a peaceful journey with the car for atleast next 3 years
Have advised the owner of 99rpm.com to stock Brembo discs and brake pads for Palios , Puntos. He said he is looking into ways to import them at a competent price
Thanks Vijaycool, Surya and Peter for your invaluable help
