T treax New member Joined Jan 9, 2015 Messages 3 Points 2 Jan 20, 2015 #1 Does anyone know how i can adjust my drivers door so it shuts further because its looking a bit proud and water is leaking in past seal Fiat Panda Active 2005 Last edited: Jan 20, 2015
Y ytareh Established member Joined Dec 11, 2005 Messages 534 Points 211 Jan 23, 2015 #2 Normally on most cars you undo hinge bolts and reposition them slightly .
V varesecrazy Patron member Parked in the garage Written 10+ guides Written a review Joined Apr 27, 2011 Messages 37,036 Points 10,559 Location Near the M4 Jan 23, 2015 #3 ytareh said: Normally on most cars you undo hinge bolts and reposition them slightly . Click to expand... Hinge..|?? to undo /slacken the catch mechanism, and then carefully/ firmly shut the door, with your body weight behind it.., then lift the door handle to release the catch, tighten the fixing bolts - door should now latch in a "snug" position, Charlie
