Technical FIAT PANDA 100HP 1.4 16v AIR INTAKE PIPE
Donatas
Hi guys! I have question:) Maybe You can help me to find FIAT PANDA 100HP 1.4 16v AIR INTAKE PIPE, part # 51773405. Found only new one for €188 ;/ Maybe some of You have used one? Thanks in advance.
Hi DaveMcT! Thank You for the answer! May you know tubes dimensions?:) Would be nice to make some small mods with silicone hoses and metal tubes:)
have a look around some scrap yards and ebay
I suspect it will be the same or very similar on other 1.4 16v fiats
stilo and punto spring to mind
anything 100hp seems to be silly money
The standard intake collects air from the front grille so its likely to be as good as it gets for air flow. The built in plenums reduce boom noises at gear shift points.
If yours is too mangled to use just take measurements from the filter case intake and get tubes/silicone to suit. Bear in mind that for a given air pressure, doubling the pipe diameter gives 16 times the gas flow.
