Technical Fiat multipla clutches
dubburke
Can anyone tell me if all the jtd models 105, 110 115, 120, all have the same clutch? or are the higher hp models larger, or have just higher clutch pressures?
best way to check is use Eper which can be found at the top of this site. fiat seemed to have superceeded the 'old' clutch part numbers to the new part number so yes they are all the same but it's always worth double checking.
I don't know much about 120 clutch. But 105, 110, 115 clutch discs are the same. Only pressure plate is stronger in 110 and 115 clutch. You can put pressure plate from Doblo which is even stronger.
With stronger clutch you can chip-tune your engine to about 140 bhp.
