General  Fiat Ducato rear door restrictor fitting.
justpeter
Good afternoon all.
Having bought a used 2014 l2h2 Ducato and finally reaching boiling point of having to fight the wind with the rear doors whenever I venture into the back I bought some door restrictors.
Having none present and no door card I assume they were either removed or never fitted, so I've no idea if some mounting bracket etc is missing.
Having tried to fit them, using images found on Google as I couldn't locate any decent direction's/guides. I find that the doors only open to about 70* as opposed to the 90*.
I've fitted them by going up from the inside of the door and the arm out the bracket slot/hole, bolted to the body with the rubber part fixed inside the door. But once the rubber part is fixed in the door the degree of movement is restricted to 70*.
I wondered if Im missing something or there is actually some kind of bracket missing.
