crustyvan
Hello,
I have a X250 and the drivers door actuator has broken and needs replacing.
Only issue is there seems to be two types - one with and one without super locking. Don't have fob, which means I can't check if the van can superlock or not. No part numbers on the lock in there (assume its a cheap knock off part).
So if I buy a lock with super locking capability, will it still work as a normal lock if my van isn't a super lock enable van? Equally, what about the other way around (Accepting with no fob I'm not super locking anyway!)
Not sure if it helps, but the current lock has two motors in, one seems to drive the lock/unlock function is the other a dead lock actuator, as I'm not sure what the second motors would be for otherwise?
Any thoughts gratefully received!
- Model
- Ducato III
- Year
- 2007
