Technical  Fiat ducato 18 plate
Jamesphoenix32
wont lock on central locking. lights flash but doesnt lock can anyone help please?
I had a fuel card nicked the other day and this is a new job. as you can imagine manager knew van did not lock but still causes a problem.
yes it key locks only on driver side but wont lock on the passenger side or rear doors the switch on door dont work either
Hi
This is a bit of a long shot, but the sliding side door can look shut but the electrical contacts on the trailing edge don't quite make contact. The van then "thinks" the door is still open. When you try the central locking from the fob, the indicators flash rapidly several times, rather than the long single flash when things are working properly. Sometimes this can be cured by carefully bending out the metalwork on the van body where the contacts sit (it's fairly thin) and/or by cleaning the contact pads.
Hi
i WILL LOOK INTO THIS
