Technical Fiat Doblo 2017 wire diagram airbag
speed254
Hello!
I have a problem with Fiat Doblo 2017 1,3 multijet, airbag light is on and fault code is B00D5 - Restraint System Passenger Disable Indicator
I did try to change the light indicator and still same problem, also changed airbag module and same problem. I think last thing is wire signal loss somewhere, but I need wire diagram of airbag.
Does somebody have wiring diagram of airbag system?
Thank you
Hi :)
That looks a strange code format ( never mentioned on here before.. not even with Stilo..)
Have you got images of it on the Diagnostic kit?
Hello!
Thank you for your reply :) , here is a screenshot of the fault code and description. I use original Autocom with latest update.
Thank you all, problem solved.
Broken fuse for indicator airbag due to soft drink spill on ASR button making short circuit, fixed by changing fuse and button ASR.
