- Joined
- Apr 6, 2012
- Messages
- 5,066
- Points
- 1,163
The Doblo had an interesting issue with the headlights. Every time I tried to flash the main beam nothing happened. Switching from dip to main had a short delay of darkness as one would turn off before the other was on. I tried all the fuses (how long have Fiat stopped putting fuse maps on the cover?) both relays and all was well. Took the column trim off thinking switch or terminal issues; nope.
A lit cigarette had fallen into the column and burned some of the loom. A bit of tape later and the lights work perfectly again.
What odd issues have you found when chasing problems?
