Technical Fiat bravo sunroof stuck in a loop
milos911
Srbija
So, i tried self learning procedure, but sunroof just got stuck all the way forward. I took down the headliner and manually pulled it back via hex. Now the state is it goes all the way forward, and then pushes the guide wires out of the assembly above the motor. It does not want to switch to reverse in any case.
Bottom line issue is that there is something that should tell the motor - hey you are all the way foward, reverse please, and that does not work anymore. In tired of fixing the back assembly after each failed attempt, so any tip on how to resolve this will be much appreciated.
Car is fiat bravo 1.9 16v, 2007, although i dont think it matters in this case
OP
OP
milos911
milos911
Srbija
Okay, i got this one - you just clamp the motor shaft with pliers and let it try to spin forward... any idea on how to fix the back mechanism, the guides keep slipping out of it no matter how tight i make it
