- Joined
- Jun 25, 2011
- Messages
- 56
- Points
- 79
Ive discovered that the fuel tank on my wifes fiat 900t was full of rust and sludge, after being dry stored for 20 years, ive taken it off and flushed it through until no deposits are left in the filter funnel, i kept wrinsing it out with the petrol that was in the tank and refiltering it before it went back in the tank each time, also shaking it and tapping the filler end on the ground on a dust sheet each time to dislodge as much as possible, so its clean now, ive also sealed up the holes and pressure tested it with a plumbers pressure test kit and theres no leaks, and the metal outside looks in good shape..
Do i need to have it resealed or will it be ok to use as is, ive got a fine gauge fuel filter in line, will the fuel in the tank keep it from corroding more
Sorry for being so long winded
