Technical  Fiat 600D flywheel timing mark
Colorado
I am in the process of re-assembling my 600D engine. The Haynes manual says I should have put a timing mark on the flywheel when piston #1 is at TDC, so I could reinstall it with the flywheel oriented properly. I didn't do that.
Is there some other way to figure out how the flywheel should be oriented? Does it even matter? (I did line up timing marks on the crankshaft and camshaft sprockets properly.)
Just clutching at straws, is there any chance you can match up wear marks on the back of the flywheel to the crankshaft. Unlikely but some engines have a unused dowel hole that leaves a corresponding mark, or maybe an inprint from a scratch or previous damage?
Apart from that, if it will fit in any position of bolt holes then given the age of vehicle it is more than likely to have been off and repositioned differently in the past.
Hi
I am just starting a Seat600 restore and been unable to find a Haynes manual. Did not know they existed for this car. Do you still have yours and would you be interested to either sell it to me or maybe let me pay for you to get it copied for me?
Hi
I’d be happy to scan and send a copy of my workshop manual. Send a DM with contact info and we can sort it out.
Ah that is very kind of you. If it gets scanned it probably does not even need printing as it will be digital. Then easy to pass. I can then print it here. My email is [email protected]. Many thanks again. Let me know the cost. I can Revolut or Bizum if you have any of those.
