Davidporthcawl
Good Morning All
A few weeks ago I replaced the clutch slave cylinder on my daughters Fiat 500, with a lot of help from this forum and until yesterday the car was fine.
However, yesterday the clutch started to play up again and I notice there was fluid leaking from the rusty joint where the master and slave join together (I forget the technical name for the joint)
I knew that this is a common problem on the Fiat 500 and I did check that is was not leaking when I replaced the slave cylinder a few week ago, however, when I replaced the slave I didn't replace the pipe as I understand it is almost impossible to uncouple this joint.
I read a few online articles about these aftermarket joints whereby you cut out the existing rusty joint and replace with a pushfit part which I have ordered online.
Has anyone had much success with these parts and if so how did you cut the pipe, was it hacksaw etc?
Any advise if appreciated.
Kind regards
Dave
Kind regards
Dave
