The BMW S63B44TU does 7200 - and it's a 560PS 4.4l twin turbo V8.
You're clearly quoting the LFA's 1LR-GUE engine, and yes, it's redline is 9500, peak torque is actually made at 6800, and peak power therefore follows at 8700. Remember our favourite old calculation?
So having digested this, you need to remember:
A natasp engine cannot fill its cylinders as quickly as a turbocharged engine, so the only way to develop a larger amount of power is to change the other variable in the equation - i.e the rpm, so by using higher lift, and longer duration camshaft profiles, you promote better cylinder filling (remember air has a mass, so by getting it to move faster - so it has more inertia), and thus burn more (of your poorly filled) cylinders of air per minute. A turbocharged engine has forced induction, so VE is greater than 100%, and thus torque is generated at lower crankshaft speeds so there isn't the NEED to rev so hard to generate 'power' (which is, in reality, a construct that doesn't actually 'mean' anything).
I suggest that you're looking at things far too simplistically, I've said this before, and you clearly haven't heeded my advice; I suggest you read up about some key things about engine theory (and practice):
Volumetric Efficiency
What power is, vs. torque
Camshaft design
How head porting design affects how an engine behaves.
And come back to me when you have..
Anyway, my comment was in jest. You clearly thrash the knackers out of your car on an almost daily basis, and it's probably a miracle that it survives
