Technical Fiat 500 2010 Dualogic oil change
MC Moto
Płock
Good morning,
I would like to ask if anyone has a service manual or information from their own experience regarding changing the oil in the gear changing robot in a Fiat 500 1.2 petrol from 2010.
Thank you in advance for any advice.
Model
500 1.2
2010
Mileage
150
Hello,
There are 3 fluids in the Dualogic / Selespeed / Comfortmatic / F1 system.
DOT4 is the one which requires the most of the attention - it's highly higroscopic, so requires to be changed every 2 to 4 years.
There are a couple of interesting threads on the robotized gearbox on the forum - especially the ones named 'the one and only' ;)
Here's the eLearn doc on the system in Alfa 147/156. In general it's the same, some small differencies might occur - like parts localisation, part numbers, used fluid volumes, etc. The logic of the system is the same in all the cars of the FIAT group.
Hi - so the 500 only has two fluids, and there's no DOT4 used. (The DOT4 brake fluid is only used where the clutch slave is on a separate hydraulic line inside the bellhousing e.g. on the Abarth or possibly the older applications above. The clutch slave is integral with the robot on the regular 500.)
The robot uses TUTELA CS SPEED fluid. Use this if you can find it (e.g. from Fiat - it was originally their product), else DEXRON III ATF is acceptable.
Don't put brake fluid in the robot reservoir! This will destroy the accumulator.
(The other fluid is regular SAE 75W gearbox oil, which goes in the main bit of the gearbox but again, must not be put in the robot reservoir)
Nick
Put the car on the lift.
- Engage the gear control lever in "N" (neutral).
- Connect the Examiner or Witech + (Examiner Emulator) to carry out the hydraulic actuation circuit depressurising procedure.
- Disconnect the electric pump fuse F83 (30 A) during this operation.
- It is better to remove the tank and wash it thoroughly.
Oil: TUTELA CAR CS SPEED ATF DEXRON IIIFIAT 9.55550-SAI 0,7L
Will you also change the oil in the differential?
Thank you for your answers. I also change the oil in the manual transmission. Can the procedure be performed without a computer?
I have already TUTELA CAR CS SPEED ATF DEXRON IIIFIAT 9.55550-SAI
No computer needed. Just two plugs. 1.65 liters needed. Tutella Transmission. Or just SAE w75...
Yes, I know how to change the oil in the gearbox without any problems. However, I am asking whether a computer is needed to change the oil in a gear changing robot
Yes, that's possible too. I changed the oil on the C510 gearbox yesterday without a computer. You pump out the oil from the tank with a syringe and fill it with new oil. Bleeding the clutch with a computer was not necessary. But that's only if you're in a hurry.
Hello Dmitry.
Can I change the robot oil as you describe without using MES? If I wait overnight and do not open the drivers door (and also remove fuseF83) will I be able to remove, clean, refit and refill the fluid tank without needing to bleed the hydraulic system?
Thanks, Alan
Guys, servicing is not only oil change.
Those system need to be taken care of properly, there's a sequence of actions to be performed from MES in the proper order.
Can you please direct me and others to a guide to this servicing please? I didn't know that there's more to service than just changing the Tutela CS robot fluid.
Hello Dmitry.
Thanks, Alan
I don't know what gearbox you have. But on the c510 and c635 you can pump out the oil from the tank. About 500 ml. You can just remove the terminal from the battery. And lets go ride))
