- Joined
- Sep 14, 2009
- Messages
- 19,962
- Points
- 3,972
This is interesting for anyone buying an automatic Panda (sorry) 500. First make sure the clutch is not worn out. They do clobber the clutch.
More reliable as well.Personally I would swap the auto box for a normal gearbox. Probably the cheapest option there is.
There must be some more jobs or it would be a regular fix. I might just buy one of these duff selespeed dualogic cars if I can get one at give away and see if I can convert it. It could be a good source of income.Is it a simple swap? what else is there to do?
A lot the wiring and electronics are differentIs it a simple swap? what else is there to do?
End of my silly idea thenA lot the wiring and electronics are different
The cranking circuit is completely different
It has an extra safety relay so it can't start without neutral selected
This is via network canbus talking between the dualogic computer and the body computer
ECU and throttle bodies are different
Is it doable
Yes
Swap everything, but seems pointless
Can it be bodged, don't know never tried
Is it doable but just changing the clutch gearbox and selector cables
No
Not sillyEnd of my silly idea then
As I see itI see, thanks for the informative reply. On the surface it seems simple, but the reality is always different. I'll not be giving the swap a try!
I'm sure i could take a dualogic gerabox off and fully repair it. It'd take ages though, and I just don't like automatic or semi automatics to drive, so i don't have much incentive to buy one of these cars cheaply and repair it.
Yep easyIff the accumulators are like Citroens, and they look as if they may be identic, its spinof and on. If itsleaked it woyld need a clean up. Changing one of these is not lijely to be taxing. If a fill set of seeals and gaskets is available, and if you can get new solenoids it sounds like a fin task. Getting the box off would be way harder.
I watch various used car sales video bloggers and they all say that automatic cars are snapped up quickly. So i can understand the price premium. I figured it was because they were easier to drive. But you're saying they're more efficient with petrol/diesel? I wasn't aware of that.Dualogic cars command a sizeable premium over manual cars.
Robotised manual gearboxes will never be a smooth as a torque converter automatic but they are considerably more efficient.
Anyone wanting an accumulator or a refurb, try Pleiades Ltd Sawtry near Huntingdon. They know these things inside out and may still refurb them.Yep easy
But needs software, to do the job
Depressurise before removing
Bleed after fitting
Do need to confirm it's failed before charging as it's not a cheap part
