Hi guys,
Having trouble starting my car and have the glow plug warning on, so trying to check out which plug is at fault. I'm using the method described on the forum of checking the resistance from the cable to the glow plug relay. I've put one multimeter probe to the engine, other to each pin on the plug.
Red cable reading 0.6, next two reading 1 on the meter (not 1.0) and the final is 0.0. Does this indicate an open circuit? Going by the forum instructional, I should be getting 1.2 ohms.
Does that indicate at least 3 of them are not working?
Hopefully someone can advise on this, thanks.
