Fault finding on battery/alternator
Banbury, Oxfordshire
Right ok i know very little about wiring etc, only really what wire goes where etc :p recently i have been having the battery warning light coming on at first startup and for the first bit of my drive but about min or two into the drive it'll go out, but then today it stayed on all the way home from work (about 10 miles or so) even revved quite hard wouldnt go out, nothing else indicating any problem only the warning light...
So i pulled out the voltmeter thingy, plan was to check voltage of batt and then again with the car running, but no such luck, got it onto the battery and sparks were flying and smoke coming up (at this point decided probably best to give up on that way of testing...)
Anyone got any ideas of what i can try as a way of checking battery and or alternator, battery is really new mind oh and final thing is the warning light goes out when you start the car (on at first turn of ignition) and then comes back fading into half brightness (dont think its ever been over half brightness mind)
Anyone got any ideas? (n)
Do the headlights get brighter if you push the accelerator?
My 1242 did exactly the same when the alternator was knackered!
:yeahthat:
Chech the physical connection befween to the altenator first. Take it off, grease it with electolytic grease and replace. See if that cures it.
If it doesn't then look at replacing the brushes/diode pack on the altenator.
Car behaves as normal no faded lights etc, only difference is this warning light :confused:
Arch liner i've tried to have out before to no luck as the hormann arches seem to be holding it in, might be an arches off job :eek:
Bit wary about checking the voltage across battery as when i tried earlier big sparks and smoke :eek:
tried the terminals on batt no difference (n) so its probably the alternator, more than likely the wiring as it was probably stretched when spring snapped (n)
going to investigate tomorrow
Sorry to hear this Alex, could you post pics of the arches and liner please? There must be away to get it out as it being a Cinq it is essential this is moveable.
Smoke and sparks ain't too good, maybe the alternator is firing too much out and the regulator is toast.
Liam
Smoke and sparks was with the engine switched off, im going to keep a very close eye on the problem and put it off till the weekend (or possibly tomorrow - depending if i want to crawl under cinq just after 2 fillings :eek: )
Might go halfords and catch up with old mate of mine get him to check it for me :D
was the smoke from volt meter yeah?
you had it set to measure voltage, but had the leads plugged in to measure voltage. you shorted the battery through the volt meter, hence toasting it!
