FAO PAUL R need help with c/locking
W
wriddle
had a message from ash, i belive your the man with the info on nutty central locking (black connectors ???)
how not to drill through the black conectors????
lol... i tried to drill one big hole for my seaker cables, you need to drill two smaller holes, then its ok :)
Paul R
wriddle i think u got the wrong end of the stick m8 lol
i said paul broke his and had the same problem as you. i was the person that fixed it for paul
if you havent attemped to drill through them to upgrade sparker cable then the problem could be corrosion.
untwist the locking connector and have a look to see id there is any corrosion or bent connections. another possible cause could be the wire from the doors going into the fuse box also look at the wires in the doors and check that they havent rubbed on anything.
a basic multimeter will be able to check the connections
Anything With Tits or Wheels Will Cost You MONEY!!
C
7K
ChrisKnottIns
C
M
4
346
Dark Lurker
S
5
776
sly si
S
A
5
647
M
