Purecarsound
[FONT=Arial, Helvetica, sans-serif]PRICE NOW DROPPED! MASSIVE SAVING TO BE MADE
Falcon Predator EVO4+ Car Alarm System with 3 add-ons included.
[/FONT]
[/FONT]
Save up to 25% on RRP prices with this package
[FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]With all the features of the popular EVO4, (no keyfob supplied, only pager-remote is included) the EVO4+ also boasts a fantastic LCD pager remote control. As well as performing all the normal remote functions, the LCD pager remote will alert you audibly if you alarm goes off and the built in LCD will indicate which part of the alarm was triggered.[/FONT]
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Modular alarm system for the best in security & reliability[/FONT]
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Includes Loud 118dB two tone siren[/FONT]
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Anti-scanning Code learning Remote Control System [/FONT]
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Includes one LCD pager remote control[/FONT]
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Includes dual stage shock sensor, other detectors available[/FONT]
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Supports up to 4 remote control's[/FONT] (sold separately)
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Remote Engine Start with auto start for battery charging and heating [/FONT]
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Turbo Timer [/FONT]
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Silent Arm/Disarm Option[/FONT]
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Panic feature from remote control [/FONT]
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Universal Central Locking Control [/FONT]
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Total Closure Facility (for vehicles with this facility)[/FONT]
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Auxilliary output controlled from remote control (eg. for control of boot release) [/FONT]
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Engine immobiliser [/FONT]
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Last Door Arming/Passive Arming sets the alarm automatically (optional) [/FONT]
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Passive Locking locks the door automatically (optional) [/FONT]
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Flashing Hazard Lights on arm/disarm/activation [/FONT]
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Temporary shock sensor bypass from remote control [/FONT]
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Valet mode to disable alarm functions (from remote control) [/FONT]
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Full Automatic Anti Hijack or from remote control [/FONT]
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Auto re-arm prevents accidental disarming (optional) [/FONT]
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Ignition lock/unlock automatically locks/unlocks doors when ignition is turned on/off (optional) [/FONT]
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Smart chirps intrusion indication [/FONT]
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Smart dashboard status LED [/FONT]
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Arm condition memory [/FONT]
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Defective Zone Bypass prevents false alarms [/FONT]
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Car Finder feature [/FONT]
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Secure Emergency Over-ride facility [/FONT]
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Bonnet protection by supplied switch[/FONT]
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Door protection where switches fitted[/FONT]
- [FONT=Tahoma, Verdana, Arial, Helvetica, sans-serif]Boot protection where switches fitted [/FONT]
Add-on 1
[FONT=Arial, Helvetica, sans-serif][SIZE=-1]Transponder Bypass Module Part Number: TP100 RRP £38.78[/SIZE][/FONT]
[FONT=Arial, Helvetica, sans-serif][SIZE=-1][FONT=Arial, Helvetica, sans-serif][SIZE=-1]Bypasses factory fit engine immobilisers where a transponder chip is embedded in the ignition key. [/SIZE][/FONT][/SIZE][/FONT]
[FONT=Arial, Helvetica, sans-serif][SIZE=-1][FONT=Arial, Helvetica, sans-serif][SIZE=-1]The key is placed inside the bypass module which is then located in a secure place under the dashboard. A lead then runs from this and loops around the ignition barrel. This keeps the immobiliser turned off allowing the used of remote starters etc. [/SIZE][/FONT][/SIZE][/FONT]
Add-on 2
Dual Zone Microwave Detector Part Number: VDET03 RRP £48.47
- Dual Zone
- SMT Design
- Plugs straight into Predator MKIII
- Outer zone on flying lead
- Compatible with most alarms
- Tri-Colour LED alert
- Universal fitting design
- Detects forced entry
A high visibility theft deterrent that flashes blue when your alarm is armed (compatible with all alarms with an armed ground output). Can also be used without an alarm and will come on automatically when the ignition is turned off.
Electro-luminescent flashing Falcon logo
Highly visible warning the car is alarmed
Flashes bright cool blue
Can be used with or without an alarm
Easy to install
Extremely low current draw
RRP £24.99
The package is listed on Purecarsound site at £317.99
And is currently a special buy on Purecarsound site @ £289.99
For Corsa-C|UK members I can NOW do the following.
Guests £240 (20% off already discounted price, 30% off RRP £)
Fiat Forum Members £219 (30%+ off already discounted price, 40% off RRP £)
Postage is a nominal £15
FOR DEMO VIDS OF ALARM AND REMOTE START IN ACTION CLICK HERE
Fitting not supplied. Purecarsound can recommend a nationwide fitting service. Guide price for fitting of this system (with add-ons) £150.
