Technical Failing MOT on monoxide emissions...
fubar
UK
Hi all,
Had the Coupe 16v N/A in the garage lately and it keeps failing on the emissions. Particulates are fine (I blew the soot out with plenty of 99-Octane and a bottle of RedEx, lol). When it comes to CO though I fail in the mid-RPM range... idle seems okay as does higher RPM, very strange.
I've put in a new braided flex pipe/exhaust mid-section, new catalytic converter & gaskets, new air filter, new battery, new relays on the fusebox - to no avail.
Before these repairs I was getting bits of honey-comb stuff coming out of the exhaust which I was told was the old catalytic converter crumbling, I also got the horse-hair crap coming out of the back box.
Any ideas? Could there be a blockage or is this an issue with the oxygen sensor?
Particulates is usually the cat breaking like you say. But you've replaced it...
Have you reset the ECU? by leaving neg battery terminal disconnected for a couple hours which will force it to re-learn everything.
Also was it a genuine cat or a crappy generic one (they are renowned to fail).
I'll give the ECU thing a try, see what happens. It's a bit scary though as last time my battery failed I couldn't stop the alarm going off. I had to leave the battery off overnight then press the fob 15 times whilst standing on the hood release catch or something crazy like that!
What I have noticed when I've finished journey is that if I have locked the doors from the button inside - when I get out and activate the alarm I have to press once (beep), twice (deactivate) then thrice (activate alarm). It won't just lock on the first press.
Other odd things have happened such as cutting out at bends/mid RPM (3rd gear) and car alarm deactivating on it's own when left overnight (although the former hasn't happened since new battery).
My new catalytic converter is a £150 3rd party thing, a local Fiat dealer wanted £400 for an official part (so I just got the official gasket & back ring for £15). I only paid £800 for the car!
Could my old battery have confused the ECU? Reading another recent thread it could be the crank sensor going - if I put my foot down in 3rd gear I sometimes have to wait for the engine (sounds like it's catching up).
Who knows.
