Evening all, my subwoofer has blown the foam support and make an unbearable farting noise now. I've pulled the fuse so it is now inactive.
Looking for a replacement 13cm woofer has proved fruitless. The factory woofer is a dual coil design with each coil a nominal 2 ohms. If I could find one a Dayton MX5-22 https://www.soundimports.eu/it/dayton-audio-mx5-22.html would be perfect. But the only woofers available are 2 x 4 ohm woofers such as Visaton W130 https://www.bax-shop.co.uk/5-inch-s...ekvvK8T77L-0JKbr6mp6bv7zwh6IBxLDuXfuC3pSBjkdm
So audio geniuses would the 2 x 4 ohm woofers be effective driven off the factory amp? Would it be noticeably less powerful?
How about repair of the original foam support with a kit from Amazon? Has anybody had success doing this before? https://amzn.eu/d/7ZUisWL
