Technical  External Temperature Sensor
gagua
Hi.
I have tempra 1.6 (1993)
My problem is that I didn't have external air temperature sensor, so my AC reads -29 and heater or cooling starts just in "HI" and "LOW" conditions.
Luckily I found the wires to that sensor (which must be assembled in side mirror but has removed):slayer:
But unfortunately I do not know which type the sensor was - Thermo Coupler or Thermo Resistor... :confused:
I did some checks, like if those wires are shorted the AC reading is 49. Another check was that I did connection of internal air temperature sensor to those wires, but it doesn’t works - the reading was 41 and air temperature was about 26... :cry:
So if anyone knows about which type sensor is I will be glad to know this info.:worship:
gagua
BUY A NEW MIRROR TO SOLVE THE PROB.
there is no other solution, tell me your country and i will try to send it for you
Bye
