Hello,
I am trying to figure what is wrong with old Tempra (1992). It has 1.8L DOHC engine (model 159A4.000). No CAT, no lambda probe (simple pot for emission control instead). The problem is the following: engine does not want to start easily, after it does, idles pretty fine, however once the throttle is touched, it stalls immediately. If I disconnect ECT sensor, problem disappears - engine reacts to throttle by picking rpm up without stalling.
I have checked ECT sensor by measuring resistance at different temperatures and it complies with specification. Throttle position, air intake temperature sensors are within specs too. Idle control valve is new and working. It is hard to be sure about MAP and CPS sensors as it is kinda hard to check them completely with simple multimeter, but what is possible to check is within specs. ECU contacts seems clean. Wires from sensors to ECU seem ok too.
Any ideas?
Any ideas?
