Explode Sound
Explode Sound
ddonq
Every So Often I Get A Exploding Sound. Or A Poof Sound. And Then Everything Is Ok For A Maybe A While And It Happens Again. It Did It Once When I Had To Volume On Mute And My System Lost Its Memory But It Still Started Up Straight Afterwards Did Not Replace A Fuse. I Does Matter If I Rev The Car Hard It Wont Do It But When I Drive Normal It Will Happen. Its Very Strange. How Could I Stop It. I Have A 1000 Watt Amp And 6 X 9's And A 500 Watt Sub. The Amp Is Turned Down Low So I Dont Think It Could Be It. Any Suggestions
toad101
just can't get enough
south east wales
check your wireing you may have some wires touching each other, i had a similar problem the amp tripping out all the time then restarting straight away, i checked wireing and found speaker wires touching each other
abinger36
does the amp go into protect when this sound happens?? It is likely to be amp or HU if it happens to all speakers at the same time.
