General  Exhaust
General  Exhaust
Cheers dude mine don't move,just looks crap,longlife said the exhaust we have would effect the performance quiet a bit as they both don't run straight through would this be correct!
That's correct yea, if you look underneath you'll see the actual twin pipes come up and over the back box from the front of the box, next to pipe going into it. Even a replacement that is just free flowing will make a big difference.
Both cats appear to have gone missing from mine (not an MOT fail) and this gives the standard system a nice sound :)
This is not fair all these pics of twin exit exhausts mines is a single exit tucked away under the car lol i fancy gettin a whole stainless system fitted lol
Yeah then you be sending me more filth with twin tip lol
Ofcourse lol i was thinkin of a twin exit each side like this but im on the fence
OK. Re-did my exhaust hangers today and as requested, took a few pics along the way.
First, here's a 'before' pic. The reason for doing the job was excessive lateral movement of the rear part of the exhaust, rather than how the tips were 'hanging'.
Here are the parts. They are (from right to left): rear support 46810305; mid support 51804591 (I bought two of these because there are two on Stilos, but the Bravo has only one); the forward support/bracket 46830390.
Using a socket to undo the rear support. For anyone with tips that sit off centre in the rear bumper, there's an easy fix. The alloy part of the support has an oversized hole, so it can be moved about to centre the pipes.
Using a screwdriver to ease off the mid support. A good spray with silicone lubricant helps with this.
The combined front support/bracket is held on by two bolts.
Pics of the removed parts show that there wasn't much wrong with the front and mid supports (the apparent splits are where I cut the support to remove it).
It was the rear one that was shot!
And here's an 'after' picture. Compare this with the first one and you'll notice the tips now sit a little higher in the bumper cut-out. The lateral movement was greatly reduced.
Hope that was useful.
(Moderators - feel free to make put this in the 'Bravo Guides' section if you wish to).
