Hi can anyone tell me the easiest way to get off my exhaust from middle section where it is joined up coz it is stiff i sprayed some wd40 on it to try and loosen it but still the same.
If you mean at the front where it's bolted on, all I could suggest is an extension pipe for your wrench or an angle grinder, but be careful not to damage the flange on the downpipe. I had to drill out my last one took ages.
If you mean the rear end, remove the clamp, unhook the rear off the rubber hangers and bash the muffler with a mallet. Twisting it also helps free it up.
Thanks for a reply just before where it is bolted on is a connection where the pipes join together and clamped on i have twisted it and hit it with a mallet but still not coming off any other ideas like spray any lubicants on it.
