Hello,
I have a few questions around the exhaust on a Fiat Grande Punto 1.4
1. I seem to be getting a leak in the exhaust coming from the gasket between the down pipe and the center pipe. The bolts have rusted quite well and i can't tell what the bolt screws into.
Is there some sort of nut that is meant to be on the other end?
2. The bracket holding the front of the center pipe has broken. Does anyone know where i can get hold of a new one, or what i should be searching for? The bit that is broken is the metal clamp around the pipe itself.
3. When pulling away the exhaust rattles quite a lot. Looking under the car the exhaust seems to be hanging quite low. There doesn't seem to be any supports from just after the down pipe to the rear silencer. Is there meant to be some sort of bracket that is missing that supports the center pipe?
Oliver
Oliver
