General  Exhaust flexi section size req?
tonyn
Can anybody tell me the internal diameter I would need on a replacement front flexi pipe section on my 2007 1.1 Panda?
Also, I see that they come in various lengths, 200mm, 300mm etc.
What is the best length to buy?
Is it worth it
The whole front isn't too dear
Pretty sure you could pick one up for around £35
Front is 45mm and rear of flexi is 40mm I believe
I did replace just the flexi
But only because I couldn't get a centre pipe cheaply in Ireland
Better availability in the UK
As koalar says, problem with flexi is that the cat is different diameter to the pipe (it is 45mm / 40mm)
But aftermarket flexi will have same diameter front and rear
I had to cut slots in mine and squeeze it down
Not something I would recommend. Bit of an unsatisfactory bodge
If you really have to, I used 45mm x 250mm
