Hi everyone,
I own a 2013 Fiat Panda 0.9 TwinAir.
Over the past month, I have had the exhaust flex pipe replaced twice by a mechanic, but it has already developed another hole and is making an unpleasant noise again.
This time, I have decided to replace it myself. I have already bought a pipe cutter, and my plan is to install the new flex pipe using exhaust clamps instead of welding so that future replacements will be easier.
Unfortunately, my mechanic always ordered the parts himself, so I do not know the correct pipe diameter for my car. Could anyone advise me on the correct size or how to determine it accurately?
I have attached some photos for reference.
In the first image, I have marked the mounting point for a support bracket located underneath the engine. The mechanic removed this bracket during the previous repair.
The second image shows the type of clamp/bracket that was removed.
The third image shows the replacement flex pipe I plan to install.
I suspect the missing support bracket may be the reason why the flex pipe has failed twice within a month, as it probably limits excessive movement of the exhaust system and reduces stress on the flex section.
Has anyone experienced a similar issue or can confirm whether the missing bracket could be causing premature flex pipe failure?
Any advice would be greatly appreciated.
Thanks in advance!
Thanks in advance!
- Model
- twinair 0.9
- Year
- 2013
