Technical Evap Valve Solinoid
Scotchgitt
Scotland
I have the p0101-62 error, (2012 1.2 500) when revs drop to tick over the eml and yellow triangle come on then stop start
My question isnt how to fix it but more what is it, what does the valve do? Does it just take petrol vapour/fuel back to the tank?
When using MES the evap value sits at 0 at tick over and rises to 70% around town
P0101-62 fault fixed
Did the usual
Earth cable
Air filter
Map sensor
Evap valve blanked off
None of these fixed it
So i kept reading and saw a couple of posts relating to intake air leaks
So i made a smoke tester kit
Parts needed
Bike tube
Bike pump
1 l Orange juice bottle
Length of hose
Sealant nozzle
Glue gun
Smoke matches ( toolstation )
See photos - aint pretty but it works
Then plumbed the smoke machine to the vacuum pipe from manifold to airfilter
Lit a match and put it in the bottle
covered the air intake with a gloved hand
Pumped in the smoke
Found leak round cylinder 1 & 2 inlet manifold to head seals
Took inlet manifold off - about 30 mins
Cleaned head surface
Took out inlet seals and cleaned them and the surface then flipped seals 180deg.
Put back together
Re ran the smoke test - no leaks
Took for a long stop start test drive
No p0101-62 woohoo
Love the smoke machine.
Thanks for posting photos.
Did the usual
Earth cable
Air filter
Map sensor
Parts needed
Bike tube
Bike pump
Length of hose
Sealant nozzle
Glue gun
Pumped in the smoke
Put back together
No p0101-62 woohoo
Do you have any advice or a tutorial on how to remove the inlet manifold, I need to replace the seals on my daughters car.
Cheers.
Check out you -tube to see if any videos on there!.
As you are likely to become the nominated mechanic for this car :ROFLMAO: might be worth investing in a Haynes manual or the like!
Done all that, with seeing things like "dropping engine, removing injector rail" etc, etc, I was just wondering how he did it in about 30 mins!!
Hi, did you manage to find out if the manifold can be removed easily (30 mins)? Thanks
