Technical Error "check running lights" 2012 X250 3.0 180
rolopolo
Established member
Hi folks,
Since all the water ingress problems (glow plug & turbo actuator and turbo) a couple of months back,
All being ok,
But again after rain or washing the van,
I'm getting on startup a Bulb out warning light, and the display says "check running lights"
About to fix the scuttle seal and add drain pipes, also P Seal, but!
This warning is it relating to
A: the dip headlamps, sidelights, amber side marker lights and rear lights?
B: daytime running lights?
The latter which are not fitted, but I believe wiring is in place for those countries that have factory fitted DRL's
I'm thinking it's a short/wiring issue from water ingress causing this warning, as I have no bulbs out! Also generally the warnings disappear shortly after moving off,
But are becoming more often!
Anyone had similar ??
Neil
