Technical  Eobd
Technical  Eobd
Welshdoblo
Hirwaun
Hi anyone had similar problems with Eobd warning light.problem is this when I drive my 1.4 petrol Doblo having drove over 35 miles approximately the Eobd warning light comes on the temperature gauge goes to nill and the engine fan comes into play once i park for approximately a hour or so it's back to normal .thermostat ? I shall have it checked by a fiat dealer any replies much appreciated
Hi,:)
it should be leaving a stored fault code, read the code..it'll give a pointer as to what the ECU "thinks" is wrong..,
could well be a bad connection / poor earth;)
Thanks I shall check it out the earth connection oddly I had not seen this warning light on for months so you could well be right thanks Roy
