I just been out and measured mine in a similar way and it comes to the same 4.75v
not sure iv voltages have changed on different models or year but mine is 1998 1242 spi
the wire going to pin 18(not 19 misread there very small on my wiring diagram) is indeed the earth as it goes directly to the ecu but It carry s 4.5 or 5v
and the other should be 12.5 as your battery is probably getting a bit low pluss the starter drain I would expect the drop to 3.5v on the earth aslong as the other stays somewhere around 12 to 10v you have a difference between the 2 of at least 5v as the injector runs on 5v
ready for bed is right there is a 12v comon feed from the relays but the injector runs on 5 and when you measure it to ecu earth that is 5v you get a potential difference between them to run the injector
the idea behind all this is the ecu can vary it's earth voltage to keep the injector voltage common in all battery conditions
it is unlikely the test meter will be able to measure the voltage as it pulses due to the speed it happens so you will need to try the led both ways unless you know which is anode and cathode on it if it does not flash and the continuity between the wires is reasonable then you have a faulty ecu
I would mainly concentrate on the continuity of the wire you had the voltage drop on but I'm sure this is the ecu compensating for the battery voltage at the time
there are plenty of engine ecus code ecus and red keys for sale on ebay for between 50 and 100 quid and if you want to know anything about making them work on your car wile avoiding having to change your locks then contact me or post on the forum there are many ways of doing it
