General  Engine Warning Light
pdfoxy
Wolverhampton
Hi, Driving Home tonight my warning light came on, and with a message to say check engine. the engine is running fine, any ideas ? Please.
Fiat Grande Punto 1.2 360 limited edition on a 57 plate
Oil and coolant levels are fine, Brake fluid fine. problem is still the same, showing check engine.
Have not driven my car since Friday Night, been to check on it this morning, and everything is ok, all warning lights go out, everything back to normal. is it wise to take it to dealer or leave it ?.
And thank you to all of you who have replied.(y)
Still take it to the dealer. It might have gone off now but when it flashed on it will of stored a code in the ECU which Fiat will be able to look at with there examiner. This means they will either be able to delete the code if there is nothing wrong and the car just had a bit of a moment or if the code does mean something they will be able to look into it :)
Hi Guys,
Took car to dealer this morning (Tuesday 16th) needs a new RPM sensor, should be completed by the end of the day,
thank you all for your comments.
Paul.
