engine tapping
engine tapping
P
paul
a have recently bought a bravo 1.2 80sx and thre was a slight tapping noise from it but today it got worse and is there constanly. has any 1 had this problem before.
checked your oil?
1.2 egine is very tappetty at cold anyway, mine is ;)
just the way they work over time I guess :)
Dan
But my dreams they aren't as empty, As my conscience seems to be...
i checked the oil it was fine but it sounds like a metalic rattle as if some thing has broke off. could u shed some light on the problem
no its still the orginal timing belt the car has only done 36888 miles. its souns like a camshaft or tappet noise
Tensioners on cambelts have been known to fail premeturley (sp) unlikley tho :)
When was it last serviced?
just.
it was going for a service next week.is it easy enought 2 strip the rocker cover of 2 see the camshafts and tappets
Probably quite easy if you follow the instructions. But easier and safer to get it done by a garage. If they screw up its their fault, if you screw up you're screwed.
kl kl. is it easy 2 get in 2 the cam shafts 2 inspect them
I
2
1K
Dark Lurker
893
David
T
1
537
Dark Lurker
