When I used the MPI off Punto 75 [ M reg ] it wasn't coded ECU , seems that some are and some not coded , you might be lucky !
think its the no.7 pin on ecu that is for coded key
also believe that the coded ign key and matching code black box and electro magnetic ring from steering lock from any fire engined Punto will send signal to any punto fire engined ecu you may have .
just need to find the correct key for the correct car at the breakers !!
