The problem is occasionally the engine stops when changing from second gear to neutral and is fine on other gear changes. There are no engine fault codes and a fiat dealer fitted new spark plugs, fuel injectors and ignition coil, but the fault remains. The throttle control body has also been thoroughly cleaned and reset and the car accelerates well and drives perfectly on motorways. Any suggestions on what the fault is would be much appreciated.
- Model
- Panda Easy
- Year
- 2014
- Mileage
- 54000
