Head gasket went the other day on my Punto 55s (1.1) – was getting using little water use but none in oil or white smoke etc. Had Head gasket changed by a mechanic, however 20 miles down the road and the engine has seized and stripped the teeth off the cam belt. Have a suspicion that he may have put the gasket in the wrong way around and blocked the oil channels up to the head. Is this possible to do on the Punto 1.1 engine, and secondly is there a way I can check if the gasket is the wrong way round / blocking the oil ways without taking head off – eg can I take off the cam cover and put a wire down the oil way or some such to see if it only goes as far as the head ?? . May have just been unlucky, but something tells me something like gasket is wrong way ? Thanks for any advise.
