Technical  Engine oil !!!!
Is 10W 60 THE CORRECT OIL FOR STILO 2.4l ENGINE ??? PLEASE. Its not a daily driver but i try and take it out every day for an hour also take it to the midlands and back twice a month... its got 5W 30 in it at the mo and i'm topping up quite frequently.
The factory fit oil is Selenia 20K. (Semi-synthetic)
Technical Data
•SAE 10W-40
•ACEA A3
•API SL/CF
•FIAT 9.55535-G2 CONTRACTUAL TECHNICAL REFERENCE N.F405.N04
•VW 500.00 - 505.00
•MB-Approval 229.1
Any quality SAE 10W-40, ACEA A3, API SL/CF can be used. I've used AGIP SINT 2000 and ESSO ULTRA. These are all semi-synthetic oils.
You could also go full a fully synthetic SAE 10W-40, ACEA A3, API SL/CF oil.
STICK TO 10W-40.
10W-60 and 5W-30 are not correct.
The 2.4 engine does tend to be a little thirsty on oil.
