F fred505 New member Joined Dec 23, 2008 Messages 6 Points 2 Dec 23, 2008 #1 engine in my ulysse gave out got a replacement from an accident damaged unit all fitted well entered start code engine turns over but will not start. help
C cipher New member Joined Jul 16, 2006 Messages 169 Points 42 Location Lincolnshire Dec 23, 2008 #2 this would appear to be an immobilizer problem. i would check that the code is correct, If this fails, then check Fuel, Air and spark...
OP OP F fred505 New member Joined Dec 23, 2008 Messages 6 Points 2 Dec 24, 2008 #3 it is an immobilizer problem switch on ignition and both red and green lights are on enter code both lights stay on
C cipher New member Joined Jul 16, 2006 Messages 169 Points 42 Location Lincolnshire Dec 24, 2008 #4 r u sure its the right code? Does anyone know if the immob code is stored in the immob unit (Keypad) or in the Engine ECU. Was the ecu changed, is the ecu matched to the immob like in Rovers
Pat H Member Joined Jan 31, 2005 Messages 385 Points 83 Location Hertfordshire Dec 24, 2008 #5 cipher said: r u sure its the right code? Does anyone know if the immob code is stored in the immob unit (Keypad) or in the Engine ECU. Was the ecu changed, is the ecu matched to the immob like in Rovers Click to expand... I'm fairly sure the codes in the ECU. But the ECU isn't on the engine it's in the engine bay so the original one should have been retained.
C cipher New member Joined Jul 16, 2006 Messages 169 Points 42 Location Lincolnshire Dec 25, 2008 #6 the keypad immob is very simple to bypass, just need to get the engine running to do it... I would check if the ecu was changed, if it was, then are the keypad and the ecu matched pairs?
D digger58 Established member Joined Mar 25, 2007 Messages 1,671 Points 452 Location Limerick Dec 25, 2008 #7 Check that all the wires at the back of the key pad are OK, I had a broken wire and both lights on at one time, Fixed it and then disconnected key pad for good. Is it a petrol or diesel?
OP OP F fred505 New member Joined Dec 23, 2008 Messages 6 Points 2 Dec 26, 2008 #8 it is a 1.9td allwas working well with keypad before engine change didnot change ecu only engine and gearbox. Is there method of passing keypad?
C cipher New member Joined Jul 16, 2006 Messages 169 Points 42 Location Lincolnshire Dec 26, 2008 #9 PM'd you
D digger58 Established member Joined Mar 25, 2007 Messages 1,671 Points 452 Location Limerick Dec 26, 2008 #10 Check heater plugs and solenoid on injector pump, Tony
