Yes it will I have a SSQV on my tjet 150. You have to leave the electrical connection on the oem one but fit aftermarket one on the pipe the car thinks its recirculating as input to ecu. My light only comes on when at low speeds as not enough boost to lift dv 1-3psi but enough to trigger p00039 fault code air bypass circuit. Leave it for three car trips turns off
