DPF blocked..... Forced regeneration failed, in fact blocked even more.....so probably DPF replacement, oil change etc.....
Frustrating thing is that the DPF light has not illuminated once in 65k of driving, 20 miles round trip to work, mostly fastish roads, and 280 mile round trip to Kent at least monthly on motorways.... Looking for a how to if available or my local garage will sort
looking at the screen print I am ni=ow wondering if its a sensor snag as DPF temp is low? tried to upload attachment of print but not sure it worked! - it did!
it did the forced regeneration, then stopped after a minute then when I tried again later, it keeps coming up with the second screen...... I don't want to do it again as it will end up knackering the oil.
Hi Robert,
Thanks for your input, unfortunately like you I am at work today and the cars at home.... So can't check.
As for the relative readings on screen print they are:
Engine temp 92.5 degrees
Atmospheric pressure: 1013
Boost pressure: 742mBar
Air temp (Maf) 34.00 degrees
Particulate filter temperature 214.00 degrees
Differential pressure sensor 184mBar
Lamba oxy concentration 0.000%.....???? ( my ????)
Particulate filter clogging 79.93%
Particulate filter regeneration: ON
Particulate filter status: Normal Clogging
Fault codes
P1206 - particulate filter (1st level of clogging exceeded)
P2002 - particulate filter (2nd level of clogging exceeded
As for how the car was driving, perfectly normally, no hesitation at all, in fact it seemed livelier then normal! ...for a 75hp qubo, it did a 240 mile round trip last weekend along mainly motorways.
Any further thoughts?
Thanks again
Ken
The differential pressure is about 2.5PSI so quite high.
Can you take a reading with the engine off (ignition on) obviously at that point it should be zero pressure. If it's not you have a sensor, electrical connection or ECU issue. If it is zero you have either a blocked DPF or a leaking/blocked/broken pressure connection.
Robert G8RPI.
good luck,
and if nothing else..use the MES to check that the dash warning light does actually work
strange how you've supposedly exceeded 2 x levels without knowing it..
I've not had any direct DPF experience.. 2 cylinders is plenty for now..
Charlie
checked last night, as you suggested, Zero pressure so probably one of the above, I have put it into my local (NON fiat Garage) who has done all my work to date as I am unable to spare the time to fix it (w.o.r.k.....)
he was impressed with the screen prints so is looking at what was suggested....i'll let you know what the outcome is..
