alfavirusnz
My problem is the 2nd speed fan will not activate unless I push the relay contacts together. Is the temperature sensor the issue in that there is a graduated signal through a resistance signal to the ECU which it is not sending, or something else. Fan works on 2nd speed, resistor checked and ok, as is fuse.
Anyone have any similar experience?
