Technical Engine light flashing and car stalling - Fiat Punto
JodieW
London
Hello!
Newbie here, owner of 65 plate Punto looking for advice. I'll keep it short...
Car was serviced, was recommended that I had a new timing belt fitted - took it to another garage (200 cheaper than original quote) for timing belt to be changed. Timing belt was changed and the same day following collection of the vehicle, the engine light started flashing and the car stalling. Took it back to garage where timing belt had been changed and did diagnostic test, which showed cylinder 1&4 was misfiring. The took the car back and changed the ignition coil and when I picked it up, all seemed fine, however, 2 miles in the drive the same thing happened again, engine light flashing and stalling. Was advised that if this wasn't the issue, it could potentially be the ECU (computer in the car?! - apologies for the terminology!) Garage said that they wouldn't take responsibility for this as they only changed the timing belt.
I took the car to a friend of a friend who works for fiat, he did a phonic wheel drive set (?!?) all seemed fine until this morning and BAM the engine light came on again and car has been stalling.
Any advise?
Hello!
Any advise?
Go back to friend with the fiat friend and ask them to look again.
I was thinking phonic wheel relearn so fiat friend sounds on right track.
The first garage who did the cambelt has made an error. Probably they have not aligned the crankshaft pulley hole onto a small dimple correctly. Phonic wheel relearn will not help in that case.
Second possibility that the engine's not timed correctly, which is their mistake too.
They should refund you for the labor & parts for the ignition coil change. It was completely unnecessary. Of course an error that came after the cambelt job are linked. They are quite incompetent.
Hello!
Any advise?
Hi
Its likely that the cambelt work has caused this fault
Wether a poor job timing the belt.. or damage to a wire..or sensor
Odd that it will be 'o.k.' for a little while though
Where are you based.. somebody might have access to the correct plug in kit to reliably read errors
As clearing and seeing what reappears is the best way forward currently
The 'misfire 1+4' isnt the commonest 'timing belt error'.. so I think you need the engines own kit to guide you here
Easy to swap lots of parts unnecessarily
Charlie - near the M4
Can I ask if you eventually got the car fixed or what resolved this fault.
Had my timing belt replaced and then had no end of problems since. Flashing light came on as soon as I went over 70mph. Cam shaft sensor had been replaced, camshaft solenoid actuator replaced before timing belt, then timing belt, followed by all spak plugs, HD lead, O2 sensor. Nothing did job. Now it is apparently a cylinder issue and I need to get a fuel injector replaced. Aah!!
often this is because Crank and Cam timining shifts slightly with a NewBelt..
The ECU needs to "realign" the signals from top and bottom sensors
(happening at 60/70mph is the usual case)
See post by @AppleFarmer 🙂
We thought this too and suggested this to the garage after the first visit and set of repairs but they said that was all fine. Not convinced and it makes almost a 'whirring noise' when I bring it up to the bite. Have now taken it back from the garage who I have had to visit three times and spent £940 ar and trying to get a second opinion elsewhere. Will ask them to check this. Thanks
